cancel
Automatic routing spanning over different frames?
Hi all,
We are currently modelling a scenario where the factory is modularised built in different subframes. Furhermore we would like to introduce a truck which performs logistic operations carrying parts from one frame to another.
So far, I haven't succeded using the automatic routing when the truck operates over several subframes. The roadnet is built up by "TwoLaneTracks" with interfaces connecting the tracks from different frames.
Any ideas?
Johan
Re: Automatic routing spanning over different frames?
Never mind, the problem was due to a missing connector. The automatic routing logic works even for objects within other frames. As long as they are connected to the same roadnet for which your AGV/Truck is operating
Johan
