Backward scheduling logic via Simtalk
Hey everyone,
I need your help in building the following logic for my model.
Batches(BatchN) are booked/reserved on a specific Machine(M1 or M2) for a specific future date. If M1 is not available on that preferred date, check a day earlier, till it is available , then book on that date.
Setup:
This logic is on MethodN(Entrance control for BufferN), checking M1availability(date/boolean: true available, false not) and creating the batch for the delivery table(Table1) of source1.
Thanks in advance.
Kind regards,
Orxan
Re: Backward scheduling logic via Simtalk
the shiftcalendar offers a scheduling function (see help --> schedule), it returns a start date if you set the third parameter to "backward"), this date you can compare with your stored jobs...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
