Bangsow example - Loading and unloading trains
http://www.bangsow.de/detail_en.php?id=631
Hi everybody...
I'm working in a model similar with this Bangsow example.
I have one doubt, where these two methods are inserted?
Re: Bangsow example - Loading and unloading trains
Hello Gabriela,
Method_loading is the observer method of the variable start_loading and Method_unloading is the observer method of start_unloading (tools - Edit Observers...). The change of the values of the variables is triggered in the sensorControl of the track.
You can find the description of this example in my new book starting from page 345.
Best Regards,
Steffen
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Steffen,
please help me in another case, it's attached here.
 I have two problems: the first is in transporter called "trem", my attribute "collisionControl" doesn't work correctly. I intend that "trem" coupling in others transporters called "prancha".
is
    i:integer;
    fzg:object;
do
    if self.~.backwards then
        fzg:=self.~;
        for i:=1 to self.~.num_pranchas loop
        -- is there a transporter
            if not isVoid(fzg.rearMU) then
                fzg.rearMU.hitchFront;
                fzg:=fzg.rearMU;
            else
                exitloop;
            end;
        next;
        wait(self.~.hookTime);
        self.~.backwards:=false;
        self.~.stopped:=false;
    end;
end;
The second error is in method of track
(SensorID : integer; Bug : boolean)
is
do
    -- let pass the tractor
    if not @.istrem then
        -- in a train only the tractor can stop
        @.gettrem.stopped:=true;
        if sensorID= 1 then
            waituntil load.occupied prio 1;
            load.cont.move(@);
        elseif sensorID =2 then
            waituntil unload.empty prio 1;
            @.cont.move(unload);
        end;
        @.gettrem.stopped:=false;
    end;
end;
