Bug(?): DataFit not accepting any input values -- Error: Value out of range.
I am running Plant Simulation 13.1.0.996 with the Statistical Tools library version 13.0.3, and the "DataFit" object keeps giving me a "Value out of range" error no matter what input values I have.
Is this a know bug, or is it something on my end? I have attached an example modelfile.
Thank you.
Re: Bug(?): DataFit not accepting any input values -- Error: Value out of range.
Hello 7SEG,
thank you for the hint. It was a bug, which is fixed in the attached model for Plant Simulation 13.1. Your sample with 5 values is too small for this purpose. The model shows how you can generate a suitable sample.
Peter
Hi Peter,
Thanks. My original sample size was 4000+ values which didn't work either, but now it works Smiley Happy
Is 13.1.1 released yet? I cannot find it in GTAC and Help -> Check for Updates says 13.1.0.996 is the newest version.
Thanks.
Hello 7SEG.
Thanks for the good feedback. There is no precise decision when the upcoming Maintenance Pack will be released. The Maintenance Pack 13.1.1 will contain the improved version of the Statistical Tools.
Peter
