Bug Found?
I am using PS 13.1.1 and tried to call <path>.getAttrNo("string"), but got an "Unknown Identifier getAttrNo" error. I see the method referenced on the single proc Methods and Attributes window, so I tried calling the method using the german name: "holeAttrNr." This worked as expected.
Thanks.
EMM
Re: Bug Found?
I cannot reproduce this. Please upload a small example model.
Re: Bug Found?
So I stripped out my model to send over... now I can't reproduce it.
If I see it again, I'll let you know. Thank you for your support.
