Bug: i += 1?
Im working currently with Plant Simulation version 13.
months ago I used i += 1 instead of i = i + 1. But since yesterday when I used i += 1, Plant Simulation understood i = i + 2. Today I try it again, but nothing changes.
Anybody like me?
Or it happens only with me?
My code:
for var i := 1 to table.YDIm
            if table["side",i] = "left"
                 if i = 1
                       table["path",i].A.createSensor((table["length",i]), "length", "m_controlSensor", true, false, VOID, true, false )
                else
                       if table["length",i] /= table["length",i-1]
                      end
                end
         else
                debug
        end
i += 1
next
 Sorry for my dumb question.
Re: Bug: i += 1?
Hi Elisha,
can you post the surrounding code?
Re: Bug: i += 1?
if i = 1
else
end
end
else
debug
end
i += 1
next
Re: Bug: i += 1?
I have to use i += 0. It works like i = i + 1.
Re: Bug: i += 1?
do you know, that the for loop automatically increments the variable i after each loop ?
The row i+=1 is not necessary.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Bug: i = 1?
oh. I didnt know it before. Thank you.
