Bug in array find method with dates
var arr: date[]
var date_ := str_to_date("2018/01/01")
arr.append(date_)
print arr.find(date_) -- error pops up: "Incompatible types in find, argument 1: date expected."
  1. Create a date array
  2. Append a date
  3. Try to find that same date in the array
  4. Error pops up! The find method expects a date even if I passed a date...
Did I do something wrong or does the software do something wrong here?
Thanks.
Betreff: Bug in array find method with dates
Hello bpinarci,
This is indeed a bug in the software. It will be fixed in the next maintenance pack.
Thanks for reporting it!
Ralf
Thanks. In the meantime I have to loop in the array and find the value for myself.
Have a good day!
