Bugs in Tecnomatix 13.2 fluid library
Hello everyone,
Does anyone know, how to report software bugs to the developers?
I diagnosed 2 bugs in the fluid library of the Tecnomatix 13.2 while working on my thesis, idk if it is being fixed already in the new versions, although the release document of version 14.0 says nothing about it.
Thanks!
KInd Regards,
Parag
1 REPLY 1
Re: Bugs in Tecnomatix 13.2 fluid library
in such a case you could take a screenshot of the error messages that are shown and a description of the steps that lead to these errors and post all that here. Posting your model that causes that error surely also helps if that is possible.
Kind regards,
Igor
