Button in 3D
how can i create a button in the 3D-view?
Thank you very much for your help!
Re: Button in 3D
Hello Toobor,
the Button object as well as the Checkbox and DropDownList objects are currently not supported in 3D.
This will be added in the upcoming release of 13.1.
Ralf
Re: Button in 3D
Okay, thank you!
