COM Interface Python: Response from Plant Simulation
Hello everybody,
I'm using the COM interface with python and would like to use the "SimTalkMessage" function to get the response from Plant Simulation. In VBA, there exists the function, but the COM object in python doesn't support the function "SimTalkMessage".
Is there a possibility to get a response from Plant Simulation (without permanently checking the values)?
Thanks for your help.
Greetings from Marcel
Betreff: COM Interface Python: Response from Plant Simulation
I find the solution:
