Camera error.
Hi...
I'm trying to capture video. I attached camera. But it is showing error message. Any suggestions to correct error?
error msg
Re: Camera error.
That is a known problem when you use an Aero Theme in Microsoft Windows 7 (and probably Vista, too). In that case, the window size actually changes by 1 pixel when the video recording starts.
We're working on that topic but as a workaround, you can switch off Aero (e.g. by selecting another theme in Control Oanel -> All Control Panel Items -> Personalization) before you start the video recording.
