Can't import .STP file into Plant Simulation
I've an Educational License and I would like to import a 3D .STP file (126 mb) into Plant Simulation. When I try to do so, I get an error 'Importing the graphic file failed.'. Does anyone know what may cause this error and how I can fix it?
Thank you!
Guus
Way of importing I used: -> 'Open in 3D' -> 'Edit' -> 'Import Graphics'
Re: Can't import .STP file into Plant Simulation
You can get this error if the .STP file is to big. If so you can try to devide the file into several smaller files.
Hi Tobias,
Thank you for the reaction. It finally worked using a VRML file, so that will be the quickest fix for people with the same problem.
