Can't run 3D View
Everytime I try to view or create a 3D model I receive this error and Tecnomatix Plant Simulation 12.1 crashes. I am a new user and not very experienced with the Software. Any help is appreciated. Thank you in advance.
Re: Can't run 3D View
Hi Deputyshooter,
this is most certainly a problem of your graphics driver.
Please make sure that you have the latest version of the graphics driver installed.
If this doesn't help go to File->Preference, select the 3D tab and the choose a lower level for OpenGL. E.g. try 3.1.
Ralf
Hi Ralf
Thanks a lot. I changed the OpenGL level and it worked perfectly fine.
Deputyshooter
