Cannot Access the MUs in Z dim of Transporter with for loop ?
I am trying to unload the transporter using the for loop method. the problem is when I increase the z dim, it does not work but if i give the value in y and y dim of transporter and keep the z dim as 1, it works.
I am not understanding this behaviour.
Why this happens? anyone have any clue how to get rid of this?
Re: Cannot Access the MUs in Z dim of Transporter with for loop ?
could you post your model or the code of your method?
Kind regards,
Igor
Hallo Igorkunjavskij,
Please find the method below in the pic
@.cont returns everytime the same MU, the single MUs you can access with @.MU, if you move one MU the index will change, so it is better work from backwards:
for i:=@.numMU downto 1 loop
if @.MU(i).name="order_c" then
end;
next;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you Mr. Bangsow. That worked perfectly
