Cardfile Read and Remove
How do I read the contents of a cardfile row and then remove the contents?
I know that with a queue file I use the .pop to accomplish this, but I cannot seem to find anything that works for the cardfile.
4 REPLIES 4
Re: Cardfile Read and Remove
Have you tried cardfile.cutRow ?
Yes that worked for me.  Thanks!
'cutRow' is no longer documented and might not be supported in a future version.
I would advise to use 'remove' instead (which does exactly the same).
Thanks for the information.
