Certain workers carrying certain parts
I am modelling a simple plant where workers carry 3 different MUs between various single-procs.
I am using the carry part away exit function along with an exit control to tell the workers where to take the MUs.
My code at the moment is essentially:
If @.name = "name"
waitUntil frame.singleProc.occupied = false
@.destination := frame.singleProc
@.move
My question is, is there a line of code I can add to specify which workers can carry which parts? i.e. worker X carries part 1 to singleProc and worker Y carries part 2 to singleProc2
I have had limited success using services on the carry away exit option, but I am still getting workers carrying parts that I'd rather they didn't.
Many thanks
5 REPLIES 5
Re: Certain workers carrying certain parts
in the exit control you can only change the service of the transport importer
or you program an importer request control for the broker, there you can check the available worker and select the right one...
what was the problem with the services?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I want certain workers to carry certain parts from the source to their station.
I.e.
A weldWorker, with weld services, carries a part to be welded to the weldStation.
By offering the weldWorker's services on the carry away function on the source, I now cannot stop the weldWorker from picking up a different part. I am then met with an error as the weldWorker is trying to take the part to a station that does not accept weld services.
I could have a specific "carry" worker who completes all of the transportation, but this is not what I am after.
I hope this makes sense?
not really
the broker mediates the worker only, if the requested service is the same like the offered;
this mean, you need to change the requested service of the source depend on the destination of the part
--> see help: setServices
Steffen Bangsow
web: www.bangsow.eu
@MRB1
This is how you set the individual services to
address the A/B/C workers to pick the A/B/C parts
Have a look:
Perfect, thank you.
