Change Background Scale
On Version 14.2 creating a 2D frame.
I dragged a .dwg into a frame as a background. While putting it in, I applied a scale to it. How do I edit the scale again?
Re: Change Background Scale
Drag it again with a better fitting scale factor ... (Plant Simulation doesn´t keep the dwg internally but converts it into a bmp, so a rescaling of a bmp would not work well).
Always consider using the AttributeExplorer!
