Change code from German to English
I have  code  in  methods  in german launguage. I was wondering if there is easy way to convert to  english. I tried good translate but it is  not exact.  I could  porbably do it if there was list of functions both in german and english.
Thank you for your help.
Manan
3 REPLIES 3
Re: Change code from German to English
When you select an object in a Frame and press the F8 key, a window will open which lists all attributes and methods. If you increase the width of the window, you will see a column that contains the other name of the attribute/method.
Thanks.
Apprantly not all the functions are there.
you will not find a translation for user defined attributes and methods
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
