Change data type in row name
Hello fellow programmers,
I wonder how I change the name/data type of the row in a table? I hope the picture I added is viewable, but as example, I have seen that some tables have "string" instead of "1".
Thankfull for your help
Re: Change data type in row name
Hi Tintin,
The datatype is determined per column, not per row. Alternatively you may use strings for the entire table and convert afterwards (e.g. str_to_num() ).
Gert Nomden
Digital Factory Consultant
cardsplmsolutions.com
the picture shows the activated column-index; the column index (row 0) can have a different datatype( by default string) than the other rows of the table
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
