Change jt color
Hu guys,
I need to modify the color of imported jt objects. The user will select the desidered color from a drop-down list.
I see it is possible to change the color opening the graphic structure, then selecting the lower node of the object and finally changing manually the color.
I can't find the simtalk command to do that, can you help me?
Alessio
Re: Change jt color
the command is ._3D.setGraphicMaterial(...)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
