Changing Tab Colour
Hi Forum
Does anyone know if it is possible to change the colour of a tab heading in a dialog?
Hermias
6 REPLIES 6
Re: Changing Tab Colour
You can change the color by selecting the area. Then List -> Format -> Backgroud Color.
Thanks for the reply!
I'm just not sure what you mean by selecting the area?
To clarify: I want to change to tabs in a dialog box similar to the picture below but so that they are not all grey. Where would the area be you are referring to?
Hermias,
As far as I know this is not possible.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Thanks for the feedback.
Are you aware of any functionality to make dialogs look less "bland" apart from adding pictures?
I'm sorry I misunderstood what you were looking for !
As Nomden I don't think so if it's possible !
Not the dialogs themselves.
You might be able to build an HTML-page and use that to interact with the model (SimTalk: openHTMLWindow). But then you probably miss some of the other functionalities of the Dialog object that you are looking for.
Gert Nomden
