Changing color in 3D
I found a method to change colour in 3D in help file
MySingleProc.set3DColor(makeRGBValue(255,0,0)); -- colors the SingleProc in 3D red
I have tried using it on a line, by having a sensor which will trigger this method  and change the color of MU moving on a line. But, i am getting error as "Unknown Identifier".
My method is
@.set3dcolor := (makeRGBValue(255,0,0));
Can someone please point out mistake in method.
Thanks in advance. . .
5 REPLIES 5
Re: Changing color in 3D
Have a look at "Create State Object" (3d)
Here you can create an individual 3d state object ( e.g. red Mu)
and trigger it through a created corresponding 2d (state) icon ( for instance "red")
by calling @.currIcon:="red";
You can also use the method:
@._3D.setGraphicMaterial (see help)
to set the color by SimTalk.
Look here for an example: http://www.bangsow.de/detail_en.php?id=645
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks for quick reply. Now i am able to change graphics during simulation. :-)
thank you, Learner, for the hint to the outdated method set3dcolor. The documentation is updated.
The proposed solution will turn off the inheritance of the graphics. In most applications  it is not recommended.
It is better to create a second graphic group and switch die visibility by an instruction like
@._3d.VisibleGraphics := makeArray("graphic")
Peter
Hello Peter,
Thanks for the inputs. I have used this concept in my work.
-Regards
learner
