Chart: Showing according to Day, Week, Month
Hi Forum
Has anyone had the requirement to have an option to display a chart according to Day / Week / Month?
i.e If the Week option is selected, each week's data needs to be combined into one value and show the starting day of that week in the X-axis of the chart for each week.
I have a couple of ideas of how to do this but wanted to check if there is a quick solution easily available.
Any feedback will be much appreciated!
Hermias
Re: Chart: Showing according to Day, Week, Month
There is no quick solution for this.
I can totally understand why you would want such a feature.
That would be great.
At the moment when I need this configuration I must create it by myself.
