Coding Dijkstra's Algorithm
Hi, I am trying to code Dijkstra's algorithm, using a method, to allow MUs to go on the shortest line. I want to set the "weight" of the line as the length, and repeat this for every line. How could I do this? I also want to use arrays, but I can't find any resources for SimTalk that have this. Are there any resources for learning SimTalk other than what's in Manufacturing Simulation with Plant Simulation and SimTalk?
Re: Coding Dijkstra's Algorithm
If you use Transporters and Tracks/TwoLaneTracks you can use the built-in algorithm (yes, Dijkstra's algorithm). By just setting a destination for the Transporter, the software will calculate the shortest (weighted) path.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
I think you will find here :
http://ww3.cad.de/foren/ubb/Forum262/HTML/000112.shtml#000007
what you are looking for
Does this work for lines as well? Or only tracks and transporters?
Only for Tracks and Transporters. So, if you can use it for your specific projects depends on what you want to model. There are some cases where both approaches could work.
Gert Nomden
Referring to the modelled Dijkstra algorithms (see /read  link)
These could be adapted to work with lines as well
@smf,
refering to the modelled dijkstra algorithms (see /read  link)
If you have a look at the code. This could be adapted to work with other objects (e.g.lines) as well.
I've looked on the website but I can't find the code; could you post a direct link on here to the code? Thanks!
look here, the *.spp.jpg have to renamed to *.spp
I still am unable to open it. How do I open the spp file and not the spp.jpg?
