Collecting worker locations
maybe someone can give me a hint, I'm only a beginner with Simtalk...
The goal is to track a worker's location during the simulation (only workstation sequence is relevant though). I created an observer to check for a change in worker.location. Then the method should write the worker.entrytime, location and previous location in a table.
param Attribut: string, alterWert: any
var eZeit: time
var ort: object
var vOrt: object
eZeit := .Ressourcen.Werker1.EntryTime
vOrt := .Ressourcen.Werker1.PreviousLocation
.Modelle.Netzwerk.werkerAktionen.writeRow(1, .Modelle.Netzwerk.tZeile, eZeit)
.Modelle.Netzwerk.werkerAktionen.writeRow(2, .Modelle.Netzwerk.tZeile, ort)
.Modelle.Netzwerk.werkerAktionen.writeRow(3, .Modelle.Netzwerk.tZeile, vOrt)
.Modelle.Netzwerk.tZeile := .Modelle.Netzwerk.tZeile + 1
The writing part works, but in each line the data is "0.0000" for the time and "*.Ressourcen" for the location. What am I missing?
Cheers
Peritectic
Re: Collecting worker locations
.ressourcen.werker1 is just the class, not the instance in your frame, so you need to refer to the object instead e.g.
var eZeit: time
var ort: object
var vOrt: object
eZeit := ?.EntryTime
vOrt := ?.PreviousLocation
here is an example:
https://www.bangsow.eu/detail_en.php?id=692
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you so much for the explanation, Steffen! Your example is a great addition, I copied the location.class.name check approach to sort out unnecessary information. Now it's working Smiley Happy
