Collision control
Hi everyone,
I've got quite a simple (and maybe stupid) question.
I have transporters driving on a track with stochastic speed. Therefore, the transporters should overhaul each other. I know that the fastest transporter will call the collision control. However, I don't know which code should be in this collision control to make sure that the fastest transporter will overhaul the slower transporter in front of it. I simply cannot find it in de Index.
Looking forward to your answers.
Michael
Re: Collision control
Hi Michael,
you might want to use the 'insert' method of a MU to move the approaching MU in front of the other MU.
Ralf
Ralf
Hi Ralf,
Thank you very much! I managed it.
Michael
