Re: Combining Multiple manual and automatic operations in a single station
Dear Steffan,
Attached the sim file
take a look in my last post, the singleProcs contains the complete process
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank u Steffen.
I incorporated the same logic to my complete model.
It is working fine in case of Automatic part movement from one station to another.
But I am facing issue while I give "Carry part away" from one station to next.
Attached the zip file.
Appreciate your support.
in this stations you dont have a fixed predecessor (self.~.pred=void), you need to delete the lines for loacking and unlocking the exit of the predecessor from your methods
Steffen Bangsow
web: www.bangsow.eu
Hello Steffen,
When I try to apply the same porgram code logic for remaining 4 Loops in line, the simulation isn't working.
I have attached the details in the file.
can you post your model?
Steffen Bangsow
web: www.bangsow.eu
Hello Steffen,
I have added a Variable for all stations which intention is to display the state of the machine as per value of Variable.
Logic I tried is when:
STN_10_Pos=1 then ST10_State=Manual Work
ie when variable STN_10_Pos value is 1,3,5,7,etc ST10_State value should be "Manual Work"
when variable STN_10_Pos value is 2,4,6,8 etc ST10_State value should be "Automatic process".
This logic is required for all 4 stations.
Please find the attached sample model.
Dear Steffen,
Attached the sample model.
Need support in refining logic for Loop 2 to Loop 5.
At present operator gets stuck in Loop 2
Loop 2: before you initialize the transport by the worker, you need to wait, until the destination is empty !
Loop 3: wrong Services!
Steffen Bangsow
web: www.bangsow.eu
Hello Steffen,
Sorry to trouble you again.
The attached file does it contain loop details of my model?
That too it's in German which I am unable to decipher.
