Re: Combining Multiple manual and automatic operations in a single station
you should work step by step, I dont have time to correct all your models but some hints:
- if you transport parts without transport importer, then the destination of the parts needs to be the singleProc (station) not the workplace (otherwise the automatic unloading doesnt work)
- in 14.2 the method goto doesnt work together with the broker (just not work)
- you have an syntax error: instead of station="occupied" use station.occupied
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi Balaji,
Refer the model attached for defining a particular sequence for the stations. The controls have been put on following two spaces,
  1. Importer request control on the broker
  2. Entrance control of the workplace
Hope this helps
The model is not working.
For my scenario, part movement between station is Manual.
Hi, check the attached model for manual movements
Varun
