Compatibilty of files
Hello, I have a file in tecnomatix however, I want to use the same file in Simplan.
I wanted to know whether Tecnomataix and Simpan are compatible with each other or not?
Waiting for your response.
Sincerely,
PJ18713
Betreff: Compatibilty of files
Hello PJ18713,
I'm not aware of a simulation tool with the name Simplan.
I know the company Simplan AG which sells Tecnomatix Plant Simulation beside other simulation tools.
So can you explain about which tool you are talking?
Ralf
Hey Ralf,
have a look at this, https://community.plm.automation.siemens.com/t5/video/gallerypage/video-id/xxNGI3bjrD0TpHrVBLwAqfvIe... . I need to simulate a supply chain network but not getting how should i start!!! I also don't know if I can do that in student version!!!
Hi PJ18713,
have you checked out the information on our homepage yet?
http://www.simchain.net/de/
Alex
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
Hey Alex,
Thank you very much for sharing this information. Do you have any idea regarding the student version for SimChain? Also, can you point out some information which can help me to use Tecnomatix and SimChain altogether, at the time of Simulation??
PJ18713
Hello PJ18713,
so unfortunately SimChain can not be used with a student license, because of the limited number of objects in (Tecnomatix) Plant Simulation (please note that the simulation software is called "Plant Simulation", whereas Tecnomatix might refer to other software, too).
Are you doing this for an university? Maybe they have a Researcher-license for Plant Simulation?
Alex
