Connecting 2 tracks with different hights by a declined track
Need any help to define how to Connect 2 tracks with different hights (by a third declined track)
thanks
3 REPLIES 3
Re: Connecting 2 tracks with different hights by a declined track
Hi @SG,
Access the Examples Collection menu inside the the Start Page>Examples/Infos:
And then, filter the search as showed below:
This model will help you to get the answer.
Best Regards,
Paulo Araujo
This should simply be possible by inserting the connecting track with two clicks - the first on the predecessor track and the second on the successor track. The height information should be used automatically correct.
Thank you Peter  I had problem with base height every thing is OK now.
