Connectors in 3D
The following capture says it all.
Is there a way to make connectors in 3D that are made of several segments?
We can do that in 2D but the connector appears straight in 3D.
This may seem like a minor issue for you but I am building a 3D model with a lot of connectors and need to be able to arrange them neatly.
Cya!
Betreff: Connectors in 3D
Hello bpinarci,
Currently this is not possible. We didn't get much requests for this feature in 3D therefore it wasn't implemented. Would be great to get some feedback who else would benefit from this feature.
Ralf
Thanks for your reply.
Usually when I encounter an issue in Plant Simulation, the software is flexible enough and I can always find a solution.
But for this case... I looked for workarounds but cannot find any.
