Control Worker with table
Hi everybody,
i want to control a worker with a table.
The worker shouldn't sort the importers due to the time they request his service.
He should work mindless and stupid, step by step on the basis of a table...
Can somebody please help me?
3 REPLIES 3
Betreff: Control Worker with table
Hello C__M,
you will find anm example in Examples-> Small Exampples: Category: Resources, Topic Worker, Sequence of stations.
Hope this helps.
GG
GG
Hi GG,
thanks for your reply.
In the example model the worker still waits until a station request his job.
That costs time.
I want him to go to the next station whether there is a part or not.
Then he waits until the part comes and do his job. (in the best case he arrives at the same time, like chaku chaku without carrying the part)
Can you please help me?
Hello C__M,
you can use the release control of the importer and sent the worker to the next station using the goto command.
Hope this helps.
GG
GG
