Control the moving times of the Pick and Place tool?
Hi everybody,
I have a Problem with the Pick and Place ( P&P) tool.
I want to control the moving times of the P&P tool. I want to determine the time the P&P tool needs to move from one station the the following station.
I used the help of Tecnomatix plant simulation but I can´t understand how does it works with the timescale of the P&P tool.
I am quite agreeable to write in german.
kind regards
Re: Control the moving times of the Pick and Place tool?
I extend the help a little bit:
you set the times in the times table, separated by empty and loaded movements. If you want e.g. drive from the Quelle empty to Einzelstation, then set the value at the crossing of Quelle (y) and Einzelstation (x). For loaded drives you set the times below the diagonale with the zero-values.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I got it!
Thank you so much for your prompt replay!
kind regards
