Control the recoveryTime
Hi Everyone.
I want to know if it is possible to control the recovery time in plant simulattion.
I want to put my own condition when the recovery will start
I look on plant simulation it give me three possibilities (when part enter, when part exit , when process is finished) Or I want to put another condition
is it possible or not ?
thanks for your answers
Re: Control the recoveryTime
Hello Manu15,
when you select the "formula" - distribution, you can select a method. So maybe on this way you can control the recovery time.
I hope i was able to give you a little help
David
