Controling line flow
I'm having some problems simulating this case:
Beetween 2 machines I have a line and, for security reasons if the line has 5 MU's the sucessor machine should stop. If the line have more than 20 MU's the previous machine should stop. How should I write the method?
Thanks.
João
Re: Controling line flow
you could use a observer control for line.numMu. Within this control you can lock and unlock the exit of the predecessor and the entrance of the successor e.g.
(param Attribut: string; oldWert: any)
is
do
  if line.numMu <6 then
	predecessor.exitLocked:=false;
	successor.entranceLocked:=true;
  elseif line.numMu >=6 and line.numMu <=20 then
	successor.entranceLocked:=false;
  else
	predecessor.exitLocked:=true;
  end;
end;
You need a init-method to unlock the exit of the predecessor in this case.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks a lot!
