Convert a string to a 3D object
Hi all,
Is there an equivalent function to str_to_obj that converts a string into a 3D animation object?
I need to access the path of a 3D animation object after calling its name from a table file.
Best,
Lucy
Re: Convert a string to a 3D object
_3d.getObject(..) is not the exact equivalent but close to.
Right, okay that makes sense to me. I'll go try it!
Thank you!
There is another, slightly more difficult, but more general approach:
If you have the paths in your table is the form
Object._3D.getObject("Subobject").getObject("Subsubobject") (. etc...),
then you can use the following term:
execute("-> any" + chr(10) + "return " + str)
wherein str is the path you get from your table.
That way, you can access everything for which you can write the path down, say, for instance, failures, animation paths in 3D objects, animatable objects (as above).
The trick behind this is that you don't see your path as a path but as a piece of SimTalk code.
Thank you!
The first code suggestion I couldn't quite get working in this context but the second reply helped a lot!
My simualtion is now running.
Best,
Lucy
