Count MUs at drain
is it possible to count the MUs that income at the drain?
i tried it with a Method  at Drain control entranceand and a global variable.
is
do
count:= count+1;
end;
but it doesn`t coutn the MUs.
or has it to be something like this
is
do
              if (income MU in Drain) then
count:= count+1;
end;
Re: Count MUs at drain
the drain itself collects a lot of statistics, the number of MUs is
drain.statNumIn
If count is a global variable and the method is the entrance control of the drain, this should also work:
is
do
count:= count+1;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello I don't know if this ist what you wanted but you can see the number of MUs at the Drain with the "Display".
User Interface -> Display -> Path ->select object Drain and statNumIn
You can also fill in the comment window with what you want to show.
