Count time between to separated processes
Good morning, I need to measure the time between to single processes which are so far one from each other. How can I do it?
Thank you
Betreff: Count time between to separated processes
Hello Santiago94,
You could define variables which are updated after each process.
For example:
t1: time for 1st process
t2: time for 2nd process
So when the processes take place, you can update the difference into another variable or a table. Hope this helps.
Simpulse
