Crane Library Plant Simulation 13.1
Hello there!
I have been trying to create a simple model using crane library. The model contains a multiportal crane with one portal, two Singleproc and store. I have been getting errors of all sort.
Does anyone have a similar model? It would really helpful to figure out this library.
I have attached the model file. Any help would be appreciated.
Thank you.
Betreff: Crane Library Plant Simulation 13.1
Hello Harshal_Varpe,
sorry, but I was not able to download your simulation model.
First, version 13.1 of Plant Simulation is out of maintenace. We recommend to use version 14 or higher.
In version 14, the library of MultiPortalCrane was redesigned, so it will be easier for you to use the library.
Look at the example collection. In category Libraries, Topic Portal Crane you will find some examplesof the portal crane.
Hope this helps.
GG
Hello GG!
Thank you fro replying.
I have checked the example model on both versions (13.1 and 14). The examples seem pretty straight-forward. Yet when I've tried to create the same model, I recieved multiple errors.
I have attached the new simulation model created in version 14 and the model in older version.
I have added the error message that I have encoutered numerous times.
Regards-
Harshal
you just have to assigne the Crane to the store and your model will run as expected.
In Version 14.1it is no longer necessary to assign the Crane to the storage are. Just connect the entrance station with the storage are and also the exit station connect with the crane, then the model will run.
Hope this helps.
GG
Hello GG,
Would it be possible for you to send me the model with changes?
I still can't get it.
Anyway thank you for help.
Regards-
Harshal
attached you will find your trial model.
GG
Hello GG!
Thank you very much. I really appreciate your help.
I shall let you know, once I successfully recreate the results.
Regards-
Harshal
