Crane Runway width error
Hi Community,
I'm getting an error on the multiportalcrane. I just imported the cranes library. dragged my crane in, changed the "Length of runway (L):" to 50 and the "Width of runway (B):" to 30.
I attached pictures of error message and my dialog.
I'm using the latest version of Plant Simulation.
Re: Crane Runway width error
look here, try the updated library
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Multi-portal-Crane-moveToposi...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you,
I do have the newest patch installed.
I have been playing around with the "Width of runway (B):" and I have been able to make it bigger by 2 metres on every apply. If I use anything larger like jumping with 10 metres it gives me the same error again.
in version 13 there was a field in the dialog with this name (not in v. 14.1).
Trigger the failure, open origine --> delete this line (it just try to write the value back into the dialog, but the field doesnt exits).
Steffen Bangsow
web: www.bangsow.eu
Thank you very much, I commented out that whole if statement and now its working.
