Crane and a resource
Hi guys, I hope that you can help me.
I am busy buildning a manufacturing model where parts are taken from one station to another station with a crane that is operated by a resource. They work in a day and night shift. I want to see the utilization of the crane and it can only work in the specified shift times but I cant seem to find a way to make the crane work in shift times. It can probably be done with a method but isnt there an easier way?
Chrisni
Re: Crane and a resource
Hi Chrisni,
Would it be an option to use a Worker-object to model the crane?
Then you could add a SingleProc that represents the transfer process and let it call two services, e.g. "Crane" and "Crane driver".
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
I wish I could but I have to simulate with a crane because it is more "pretty" in 3D Smiley Wink (Have to present to management).
