Re: Creating a street between 2 Open Street Map Points (OSM) via Simtalk
it is not that easy,
you need two coordinates: start and end; in the first step you create the object on its start coordinate (somehow you do need re-calculate the lat/lon into pixels), then you change the end position via the segmentsTable
in English (createObject is not supported anymore):
newTrack:=.MaterialFlow.TwoLaneTrack.derive(current,name)
var tab:table[integer,integer,integer]
tab.create
tab.writeRow(1,1,startXPos,startYPos,0)--start point
tab.writeRow(1,2,endXPos,endYPos,0)-end point
-- assign segments table
newTrack.segmentsTable:=tab
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks alot for your help. I will get back as soon as possible
