Data acquisition format
Good morning,
I wanted to know if someone has a data acquisition format in order to gather data for simulations.
Thanks in advance.
Re: Data acquisition format
considering a non countable amount of use cases there is no and there will never be such a general akquisition format. anyway depending on standards for (comparable) use cases such a format can be developped. technically it is just recommended to utilize the xml file format in order to reduce the effort for data treatment.
Always consider using the AttributeExplorer!
