Debugging - max num of suspending method exceeded
Hi guys,
I was running my model and, at a certain point, it stopped with the following error message:
the maximum n umber of suspended methods has been exceeded.
I attach my method for reference.
the errorr occurs after 15hr and 34 mins.
What does it mean? how can we prevent this?
Re: Debugging - max num of suspending method exceeded
the problem is the combination of observer and waituntil. The observer is called at each change of numMu, and at each call you suspend this method. So you have in a short time a big number of suspended methods.
So you cannot use waituntil in an observer method.
If you have a more complex condition to observe, you can use a combination of generator and method. If the condition is met, just do nothing.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
