Delivery Table attribute
Good afternoon,
I am fairly new with the software and need your help. Right now, I am working on a simulation project for my project.
I wanted to create Entities with (user-defined attributes) inherited from the delivery table like order number, quantity etc. For that, I want to assign nested tables to the 5th column in the delivery table with the mentioned attributes. However, when I enter the values in the Attributes nested list, I can not somehow see the value of the attributes.
I want to ask about a tip how to manage it.
Kind regards,
Re: Delivery Table attribute
you need to write the attribute names into the first column (row by row), the values you write into the column with the right datatype; do not change the format of the subtables
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you Steffen
