Dialog
Is it possible to open the dialog when i open the model or run a method when opens the model.
Att,
Re: Dialog
To show your dialog you can use the method Open.
This way : Youdialog.Open() ;
BR
O.C
Re: Dialog
You can create a method called "autoexec" in the class library. In this case Plant Simulaton will run this method when your model is loaded. From it you can open a dialog window or even minimize Plant Simulation to the tray using HideBBL operator and leave only dialog window on the screen.
Regards, Vladimir.
