Different proc. time (uniform) for MUs
Hello.
I have 3 MUs (A, B and C), singleproc "Packing"  (proc. time defined by formula with "Method_PT").
I want different processing time for each MUs.
In "Method_PT" is this code:
:time
is
do
     if @.Name="A" then
          Packing.ProcTime:=z_uniform(1, 70, 120);
     elseif @.Name="B" then
          Packing.ProcTime:=z_uniform(1, 120, 180 );
     elseif @.Name="C" then
          Packing.ProcTime:=z_uniform(1, 310, 370);
     end;
end;
I don't know if it's correct. Can somebody help me? Program included.
Thank you!
Re: Different proc. time (uniform) for MUs
Hello Libor,
Please use the below method & trigger this method in the EntranceCtrl (check the 'Before actions').
is
do
	if @.Name="A" then
		Packing.ProcTime.setparam("uniform",70, 120);
		Packing.ProcTime.setparam("uniform",120, 180 );
		Packing.ProcTime.setparam("uniform",310, 370);
	end;
end;
Thanks & Best Regards,
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
If you want to use the method as formula, you need to select formula as distribution for Process Time and enter the method as value.
The method needs to return for each MU a time value. So you need to change your method:
:time
is
do
  if @.Name="A" then
	return z_uniform(1, 70, 120);
	return z_uniform(1, 120, 180 );
	return z_uniform(1, 310, 370);
   end;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
my problems same as above. I'm using plm simulation 14. I try using simtalk as above, but failed. I'm not familiar with the use of simtalk. can someone help me to solve this method. I use 3 MU, namely LongKeropokLekor, KeropokLekorCrispy and KeropokLekorBall. MU has a processing time varies.
time
if @."LongKeropokLekor" then
return z_uniform(0.1489,4.6163)
elseif @."KeropokLekorCrispy" then
return z_uniform(0.1489,4.6163:
elseif @."KeropokLekorBall" then
return z_normal(10.6,0.10858,9.5,11.5)
end;
end
a try
->time --return value
if @.name = "LongKeropokLekor" then
     return z_uniform(1,0.1489,4.6163) -- see help parameter for z_uniform
elseif @.name = "KeropokLekorCrispy" then
elseif @.name = "KeropokLekorBall" then
   return z_normal(1,10.6,0.10858,9.5,11.5)
end
Steffen Bangsow
web: www.bangsow.eu
it can't prompt the command
  this template form method regarding the ProcTime depends on MU attribute
--Determines the processing time of a station in a formula according to an attribute of the MU.
—@ is the MU that triggers the formula
—? is the station calling this method
->time
if @.«attribute»=«value»
result:=«time»
— add your code here
elseif @.«attribute»=«value»
result:=«time»
else
end
what is your Plant Simulation version? And if it 13 and higher: do you use the new syntax?
Steffen Bangsow
web: www.bangsow.eu
Hi
Mr Steffen Bagsow,
i'm using plant simulation v14.
already activate new syntax.
i'm stuck with processing time.
the system show incorrect method
.Model.Frame.Method.
tqsm..
please check again, if for this method the new syntax is activated (method editor - tools - new syntax must be selected)
your error is typical for the old syntax
Steffen Bangsow
web: www.bangsow.eu
Hi
Mr Steffen Bagsow,
Tqsm for your guidance.
i try check using incorrect methods.
it show incorrect method.
the new method i get
->time
if @.name="LongKeropokLekor" then
elseif @.name="KeropokLekorCrispy" then
elseif @.name="KeropokLekorBall" then
end
i have  1 more question,
how can i check the MU will follow the time that are listed in the method
