Different values in the occupation chart with every run
Hey guys!
I noticed weird results in my occupation charts of my stores.
The "Increment Variant On Reset" option in the "EventController" is deactivated.
Every simulation run is done with the "Random Numbers Variant" = 1.
With these settings should be the results of the simulation equal, with every run.
But my occupation charts and the occupation tables of my stores are with every run different.
Has anybody an explanation for that?
Best regards
divantho
Re: Different values in the occupation chart with every run
Hi Divantho,
you are right that you expect the same reproducible results. I expect that the model is not set to the original state by reset.
Please save your model after reset. Perform a simulation. Reset the model. Compare the saved model with the current model (Menu File > Compare Models). You will detect the changes that were not reversed by reset.
Peter
