Different works in the same assembly
Hallo guys,
I try to simulate an assembly workplace in which the worker assembly different final products.
I found Different works in the same assembly-Discussion. I tried to simulate this but couldn't do it. I attached a screenshot.
Different works in the same assembly-Discussion:
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/Diferent-works-in-the-same-As...
Could you look at it?
Best regards,
Beril
Re: Different works in the same assembly
I guess the new syntax is activated; delete is, do and the last end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I have done but still it doesn't work...  I added the simulation.
If you have some Time, could you look at it?
the conversion to new syntax damaged some line in your program. Activate new syntax;
this should work
var t:table[string,integer]
t.create
if @.name="FinalproductA" then
 --write the parts into the table (name, quantity)
  t.writeRow(1,1,"A",1)
  t.writeRow(1,2,"B",1)
  t.writeRow(1,3,"C",1)
elseif @.name="FinalproductB" then
  t.writeRow(1,1,"A",0)
  t.writeRow(1,2,"B",2)
  t.writeRow(1,3,"C",2)
elseif @.name="FinalproductC" then
end
--set t as the assemblyList
?.assemblyList:=t
Steffen Bangsow
web: www.bangsow.eu
I try but it doesn't work. I added a screnshot.
okay, you are using version 12, so you need the old syntax (SimTalk 2.0 is in this version not available)
see model
Steffen Bangsow
web: www.bangsow.eu
Thank you very much Smiley Happy it is working now.
Best wishes.
Beril
