Dismantle a pallete
Hi.
I am new to this software and I am using it for school purposes.
I have a problem with dismantle station. From source i am generating using delivery table 20 palletes that are filled with 720 bottles each every day. After that one pallet goes to store and from there I want to use dismantle station to extract bottles from pallet to second store and after use those bottles in some other procceses.
How can I configure the dismanltle station.
Please help
Mateo
Betreff: Dismantle a pallete
acc. to help file, set the dismantle mode to : "Detach MUs"
Re: Dismantle a pallete
you can have a look at the attached example model which roughly resembles what you just described. Here the Dismantle station is also used, so you can have a look at its settings for your use case.
Kind regards,
Igor
